[commande groupée] ordinateur de bord FZS 600
david_38
Re: [commande groupée] ordinateur de bord FZS 600
Message par david_38 »
Spartiaxe a écrit :La mienne est de 99 donc il y a des transformations à faire . Ajouter 2 boutons et une sonde pour l'huile ou liquide de refroidissement c'est ça ?
Oui c'est bien ça! ..
pour ma part j'ai ajouté un 3 ème bouton sur le commodo pour changer les vues
zorglube
Message par zorglube »
Phil et moi sommes en contact avec le fabricant d'ordi.
Il fabrique toujours.
Pour les FZS 99 il fourni le bouton supplémentaire et recommande une sonde pour la température.
Ci-dessous la conversation :
code : Tout sélectionner
The 2003 is no problem to install, just the speedohealer function makes no real sense and should be omitted.
For the 1999 it depends. Does the dashboard has two buttons? Or only one? In that case you have to also install additional buttons. I have some pictures how to do that and will also provide the buttons.
Also you would need an addtional temperature sensor (only for the 1999). My recommendation is to use one from Koso and exchange it with one of the temperature switches in the thermostat. An oil sensor is the alternative, but it's much less accurate.
I’m the owner ot the 99’. My dashboard has only one button. You would be very nice to send me the picture you have.
I’m really interested in the temp sensor.
to make things easier I've quickly uploaded some pictures onto my website. Please have a look : cvieth.bplaced.net/bilder/ganganzeige/fzs600
Koso provides the sensor in several variants. They only differ by housing and thread.
BF030125 is for replacing the original switch in the water thermostat.
BF140150 is for to replace the oil drain plug.
My recommendation is the first (for water). He gives higher accuracy due to better thermal coupling.
The extension cable is also needed, it comes with the proper connectors.
For the buttons you would have to modify the dashboard housing, according to the sketch. Buttons are closing to ground, no additional resistors needed (my installation document shows a slightly different, alternative cabling).
I can provide the buttons, but unfortunately I have no sealing caps. They are available e.g. at "Conrad", an electronics supplier. Googling for the partnumber from the bag should also bring results.
Big-Shell
Message par Big-Shell »
Bonjour à tous.
J'aimerais bien voir des photos SVP :D
Bonne Journée.
║.Image.║
║ Photo :║ ImageImage
zorglube
Big-Shell a écrit :Bonjour à tous.
Bonne Journée.
http://cvieth.bplaced.net/ganganzeige.html
Big-Shell
Bonne Journée.
Merci :D
║.Image.║
Mantis
Message par Mantis »
Le gros chiffre à droite c'est l'indicateur de rapport vitesse ?
zorglube
Mantis a écrit :Le gros chiffre à droite c'est l'indicateur de rapport vitesse ?
C'est une indication de l'anti patinage, c'est le nombre de bougies actives.
mandrake77
Message par mandrake77 »
Si on commande, y 'aura-t-il un expert qui puisse nous l'installer? :D
zorglube
mandrake77 a écrit :Si on commande, y 'aura-t-il un expert qui puisse nous l'installer? :D
Si commande il y a, je peux te donner un coup demain Phil aussi probablement. De là à dire que nous sommes des experts, faut pas pousser, mais en tous cas le bricolage et les soudures ne nous font pas peur ^_^
zorglube
Personne n'as réagis... Sérieusement les gars !!!??? Un anti patinage sur une FZS... C'est la vitesse engagé le gros chiffre.
